Date/Time: Sun, 12 Jan 2025 10:43:08 +0000
Just paid for data fees, how do I connect?
View Count: 591
[2017-02-17 16:11:02] |
User135901 - Posts: 5 |
Hi, Just paid for data fee for futures CME, Globex. How do I connect to get the real time data on my charts? How long will it take? Thank you. |
[2017-02-17 16:18:18] |
What Data or Trading service do you wish to use? See this page for the list: https://www.sierrachart.com/index.php?page=doc/Data.php Or, if you heard about Sierra Chart from a trading/broker service and want to use their service with Sierra Chart, tell us which one you were referred from. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-17 16:48:10] |
I would like to use Sierra chart data service.
[2017-02-17 18:24:36] |
OK, we see that you tried to activate the Sierra Chart Exchange Data Feed but there was an insufficient balance at the time you did. There now is a sufficient balance. Just follow through the setup instructions here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions The exchange you need to activate is: CME, Globex only (For users without a trading account): Price 42 USD/month. There is no cost for this for the first month. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
