Date/Time: Sun, 12 Jan 2025 12:56:15 +0000
Version 1521 > Market Depth Numbers not visible anymore?
View Count: 681
[2017-02-17 14:36:45]
User51760 - Posts: 108
Hello Support Team,
having updated from V 1518 to V 1521 I do not see Market Depth on the SC-Trading-DOM anymore - however I receive the data.
I am using Sierra Chart Real-Time and Historical Exchange Data Feed.
Any Idea what I am doing wrong or what needs to be tweaked?
Best, Chris
image2017-02-17_135142.png / V - Attached On 2017-02-17 14:35:01 UTC - Size: 14.37 KB - 234 views
[2017-02-17 15:42:25]
Make sure the Bid Size and Ask Size columns are added to the Trade DOM.
Go to the trade DOM and select Trade >> Customize Chart/Trade DOM Columns.
[2017-02-17 18:12:09]
Ok, I figured it out: I needed to replace Buy Column/Sell column with
Bid Size/Buy Column
Ask Size/Sell Column
and everything is back to normal again.
However, I did not change anything myself before the update: the Bid Size/Buy Column and the Ask Size/Sell Column just disappeared with the updating from Version 1518 to Version 1521. This just as a feedback and observation.
Thank you for your support!
imageDOM.png / V - Attached On 2017-02-17 18:11:10 UTC - Size: 22.66 KB - 208 views
[2017-02-17 19:05:12]
This is the result of a reconfiguration that was done and relates to the ability to set these market data and trading columns individually for each chart.
We will make sure the defaults include the bid size and ask size columns.
