Date/Time: Sun, 12 Jan 2025 10:51:57 +0000
CL Not Rolling Over
View Count: 634
[2017-02-17 12:54:11] |
infpz - Posts: 826 |
For the last few months, I've noticed CL is not rolling automatically into the next month. This could just be the way the calendar has shaped up, but can you check? Today for example, we are definitely in April Crude (Vol is 3X March) but when I open a new CLH7 chart with Automatically Rollover Futures Symbol checked, it does not roll into April. |
[2017-02-17 15:44:19] |
We have to adjust the rollover rules. We will analyze this and make the necessary adjustments.
