Date/Time: Sun, 12 Jan 2025 12:53:23 +0000
no color change large volume indicator
View Count: 1178
[2017-02-17 05:40:36] |
User99934 - Posts: 227 |
There used to be a color change when large volume indicator was used with market depth chart. Now it is all one color. Please see pic.
large vol ind.JPG / V - Attached On 2017-02-17 05:39:55 UTC - Size: 115.05 KB - 345 views |
[2017-02-17 19:22:47] |
We will only accept this method when posting an image of a chart: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image You need to remove all other studies from the chart. If the Market Depth Historical Graph study is affecting the colors it is only because you are using transparency with the Large Volume Trade Indicator and the blending is causing a different color. This is normal. So we do not recommend that you use transparency. Set the Use Transparency study Input to No. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
