Date/Time: Sun, 12 Jan 2025 10:46:36 +0000
Sierra Chart slave and master mode
View Count: 1119
[2017-02-17 02:55:11] |
User549046 - Posts: 3 |
Is there a slave and master mode on Sierra Chart. I want to use master on server and slave on computer?
[2017-02-17 03:06:19] |
There is the DTC Server which may accomplish what you want: Data and Trading Communications (DTC) Protocol Server Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
