Date/Time: Sun, 12 Jan 2025 11:09:19 +0000
Historical data download issue
View Count: 729
[2017-02-16 23:07:52] |
User54286 - Posts: 1 |
I am having trouble downloading some of the symbols by using SC Data service. For instance I was able to download symbols such as ZS, ZL, GC,...but download failed for SI, PA, CC and others. I went through http://www.sierrachart.com/index.php?page=doc/HistoricalIntradayData.html#h7.1 but still I could not find the answer to my issue.
log.txt - Attached On 2017-02-16 23:07:06 UTC - Size: 299.29 KB - 378 views |
[2017-02-17 03:33:52] |
We have looked at the Message Log and this is one of the messages: HD Request # 13 | Error downloading historical Daily data for SIH17. Not downloading any data. Maximum downloads exceeded for the day. Limit: 2000 | 2017-02-16 23:05:33
Refer to this section for instructions: https://www.sierrachart.com/index.php?page=doc/SierraChartHistoricalData.php#UsingSCExchangeDataFeedAvoidDataLimits There is also an extremely large number of errors related to Continuous Futures Contract charts due to incomplete data. So you may also want to reduce the number of days loaded in the Historical charts to reduce the number of requests which are failing due to the limits. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-02-17 03:34:42
