Date/Time: Sun, 12 Jan 2025 10:49:13 +0000
Question on Bid Ask Volume ratio study
View Count: 2083
[2017-02-16 21:11:47] |
NumbersBars - Posts: 141 |
Currently in Bid Ask Volume ratio. Ratio calculation is fixed as follow: Ratio = 100.0f * (AskVolume - BidVolume) / TotalVolume; Just wondering, is it possible to have an option for user to choose between (BidVolume-AskVolume) or (AskVolume-BidVolume)? Just like the options available in Bid & Ask Depth Bar study. Thanks. Date Time Of Last Edit: 2017-02-16 21:12:12
[2017-02-17 04:10:29] |
Yes we can add this.
