Date/Time: Sun, 12 Jan 2025 11:05:29 +0000
Hidden or Ignore
View Count: 1019
[2017-02-16 19:58:31] |
Crtfyd - Posts: 281 |
I read the differences between "Hidden" or "Ignore" for a study. Mainly the showing of the data in the scale range. I am referring to a study from a Color Bar with Alert Condition, so I don't need to see the study its referring to. Two questions. 1-If "Ignore" is used, does the computation still happen so my Color Bar can still "refer" to it? 2- The reason I want to do more than just "Hidden", is I'm trying to lighten the load on my computer bc I have a lot of Overlays, so it is slow (i3 dual-core-8mb RAM). So I thought every little bit would help. Does this make sense?...or is basically the difference in only the "printing" of the data to the scale range, so no real added load even in my case. (I have over 28 Overlays) |
[2017-02-17 04:33:27] |
We have updated the documentation for these Draw Styles here to answer these questions: Chart Studies: Hidden (ACSIL: DRAWSTYLE_HIDDEN) Chart Studies: Ignore (ACSIL: DRAWSTYLE_IGNORE) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
