Date/Time: Sun, 12 Jan 2025 11:07:10 +0000
Number Bars (footprint distortion)
View Count: 1455
[2017-02-16 17:38:00]
User713850 - Posts: 33
I like the visual layout of the attached pic but the number bars (footprint) is very distorted. How do i change the scaling parameters so there is less distortion on the bars?
imageNumber Bars Distortion.PNG / V - Attached On 2017-02-16 17:36:10 UTC - Size: 88.11 KB - 564 views
[2017-02-16 18:10:31]
This is explained here:
http://www.sierrachart.com/index.php?page=doc/NumbersBars.php#Scaling
Also when posting an image of a chart we will only accept this method:
[2017-02-16 18:55:47]
The issue is not just being able to adjust the number bars without distortion. The issue resides in not being able to view the left profile in conjunction with the number bars after the distortion for number bars is adjusted. Hence the reason why i stated i preferred the visual layout of the overall picture which was initially sent.
http://www.sierrachart.com/image.php?Image=1487271084455.png
I need to view the profile on the left in a clear manner without the number bar distortion being present.
[2017-02-17 03:21:12]
You have to reduce the chart font size or you could also set this Volume by Price study Input to Yes:
https://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#Input_AlwaysDisplayLastProfileWithinView
Or use a larger high-resolution monitor.
