Date/Time: Sun, 12 Jan 2025 12:08:07 +0000
Unstable performance - Relative Volume Study
View Count: 827
[2017-02-16 15:08:13] |
User299392 - Posts: 216 |
It just comes right and then disappears. Especially the CVR field in this study - please. Please look into this - please. |
[2017-02-16 15:25:11] |
Ok, looks like the problem is not the study - it is this "text display for study from chart" that is made to read CVR field from another chart that is unstable. It pulls and then stops and shows zero. I must, however, mention that other places where I use this "text display for study from chart" is working fine. It is just in case of CVR and all other fields in the relative volume study that does not get populated. It was all fine up until yesterday when I downloaded 1520 version. And I have been using it for quite some time. Hope this helps. |
[2017-02-16 18:07:21] |
We want you to update again to the latest revision of Prerelease 1520. Follow these instructions: http://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate This should solve the issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-16 20:23:18] |
That did not work either. Not sure what is going on here. Please help |
[2017-02-17 04:34:46] |
We have not made any further changes, but just to make sure you have the latest changes, update to Prerelease 1521 following these instructions: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-22 19:24:33] |
I am not sure if my continuation response to this thread got posted or not - so typing it up again here. I examined this issue very closely and I figured the below to be a problem - The study (Relative Volume) starts normal and displays everything as expected. And then in about few minutes; it will just stop sending the NAME AND VALUE LABEL information to the region data line (as also the chart values window). SO much so, it will even stop displaying name and value info (of the CVR and RV fields) on the values scale of the chart. See please if you can look into this. This was a part of a normal set up until only a few recent releases ago. Please - this is important. Many thanks! |
[2017-02-22 19:34:13] |
We determined the reason for the problem. This has been resolved in Prerelease 1523 which is available now. Update with Help >> Download Prerelease. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
