Date/Time: Sun, 12 Jan 2025 10:39:15 +0000
Adding brackets to open positions
View Count: 901
[2017-02-16 13:00:01] |
User687828 - Posts: 17 |
Hello, how do I add bracket stop/limit orders to an open position?
[2017-02-16 17:57:54] |
Refer to: http://www.sierrachart.com/index.php?page=doc/OrderTypes.html#SendAttachedOrders Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-17 00:32:55] |
Thanks, a somewhat related question, how do I create a new bracket template, the DOM comes with SimpleBracket and I would like to create a SimpleBracket2 and SimpleBracket3 with different qty and stop/limit settings for different instruments.
[2017-02-17 04:24:04] |
Refer to: Basic Trading and the Trade Window: Using and Changing Between Different Trade Window and Attached Orders Configurations Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
