Date/Time: Sun, 12 Jan 2025 10:51:54 +0000
[User Discussion] - 2 differents backgrounds on indicators
View Count: 890
[2017-02-16 11:32:21]
isa74 - Posts: 54
Sir,
I would like to be able to change the background on a specific indicator without affecting the rest of the others indicators background,
neither the chart background.
I would like to place the MACD background into black.
If i go to the Global Settings > Graphic Settings but I do not see any paramater adapted for that.
Another request:
How it is possible to have 2 differents background, one specific to the chart and on specific to the indicators ?
Thanks !
imagesc_sierracharts_interface_Backg.png / V - Attached On 2017-02-16 11:15:13 UTC - Size: 61.32 KB - 245 views
[2017-02-17 05:13:01]
nicktrader - Posts: 727
For that purpose I am using one of the studies "Time Range Highlight...". You have to place that study on the region you need.
imageexample.png / V - Attached On 2017-02-17 05:12:13 UTC - Size: 9.68 KB - 232 views
[2017-02-17 12:41:56]
isa74 - Posts: 54
Thanks a lot Nick ! Really !
I have another request if you please.
I try to change the text color and the background color beneath it on the parts that comes out when the mouse gets over the timeline which is in the bottom of any chart.
See the problem i face here: https://gyazo.com/045045e2c84df591604a08a94bfcb40 or attached.
I have light grey text over a white background.
I would like to change that but I do not see where ! Even in the Global Settings > Graphic Settings, do not find..
Can you help me on this matter please ?
imagesc_sierracharts_interface_timeline_text_greyonwhite.png / V - Attached On 2017-02-17 12:40:47 UTC - Size: 4.05 KB - 222 views
[2017-02-17 14:10:21]
Hi isa74,
I am sorry but I do not really understand your problem. I assume you like to change the timeline color (background and text color). As I know this is not supported.
