Date/Time: Sun, 12 Jan 2025 10:41:01 +0000
level line that ends at given point in future
View Count: 710
[2017-02-15 23:25:19]
aydex - Posts: 110
I wish to draw a support or resistance level for todays session, but do not want it to continue into tomorrows session.
Is there a way to do this please
j
[2017-02-16 09:44:39]
You will want to use the Horizontal Line drawing tool:
Chart Drawing Tools: Horizontal Line | Horizontal Ray | Horizonal Line Non-Extended | Vertical Line
And then later Cut it on the bar where you want it to end. Refer to:
Chart Drawing Tools: Cut a Drawing
