Date/Time: Sun, 12 Jan 2025 09:50:34 +0000
Study subgraph returns -nan when referencing [sc.Index - 1]
View Count: 1657
[2017-02-15 17:29:21]
reticent67 - Posts: 4
I'm trying to recreate Ehlers Stochastic, which is basically a stochastic of his Roofing Filter (located in the user contributed source code). The final calculation of the Roofing Filter is this
Filter[sc.Index] = c1 * (HP[sc.Index] + HP[sc.Index - 1]) / 2 + c2 * Filter[sc.Index - 1] + c3 * Filter[sc.Index - 2];
This works perfectly fine. But when I take the stochastic of Filter and apply the same calculation, the result is -nan.
float highestFilter = sc.GetHighest(Filter, Length.GetInt());
float lowestFilter = sc.GetLowest(Filter, Length.GetInt());
Stoch[sc.Index] = (Filter[sc.Index] - lowestFilter) / (highestFilter - lowestFilter);
//same as Roofing Filter above - which works
ES[sc.Index] = c1 * (Stoch[sc.Index] + Stoch[sc.Index - 1]) / 2 + c2 * ES[sc.Index - 1] + c3 * ES[sc.Index - 2];
I've debugged the code and all the formulas calculate as expected. However, as soon as I try to reference ES[sc.Index -1], the result is -nan. Referencing the previous values of the other arrays works perfectly, but not the ES subgraph. I've never run into this issue before. What is it I'm missing?
Here is the entire source code for reference:
// The top of every source code file must include this line
#include <Windows.h>
#include <math.h>
#include <iterator>
#include "sierrachart.h"
SCDLLName("Ehler's Stochastic")
SCSFExport scsf_EhlersStochastic(SCStudyInterfaceRef sc)
  // Reference the Plots and the inputs
  SCSubgraphRef  ES = sc.Subgraph[0];
  SCSubgraphRef  OB = sc.Subgraph[1];
  SCSubgraphRef  OS = sc.Subgraph[2];
  SCInputRef    Price = sc.Input[0];
  SCInputRef     Length = sc.Input[1];
  SCInputRef     Bars = sc.Input[2];
  SCInputRef    Cutoff = sc.Input[3];
  //Define arrays for intermediate caclulations
  SCFloatArrayRef HP = ES.Arrays[0];
  SCFloatArrayRef Filter = ES.Arrays[1];
  SCFloatArrayRef Stoch = ES.Arrays[2];
  if (sc.SetDefaults)
    // Section 1 - Set the configuration variables and defaults
    sc.GraphName = "Ehlers Stochastic"; // Name in study overview
    sc.StudyDescription = "From Predictive Indicators for Effective Trading Strategies By John Ehlers";
    sc.GraphRegion = 1;  // Set the Chart Region to draw the graph in. Region 0 is the main price graph
    sc.FreeDLL = 1;
    sc.AutoLoop = 1;  //Auto looping is enabled.
    sc.ValueFormat = 2;
    sc.ScaleRangeType = SCALE_AUTO;
    // Define plots and inputs
    ES.Name = "EhlersStochastic";
    ES.DrawStyle = DRAWSTYLE_LINE;
    ES.PrimaryColor = RGB(255, 0, 255);
    OB.Name = "Overbought";
    OB.DrawStyle = DRAWSTYLE_DASH;
    OB.PrimaryColor = RGB(128, 128, 128);
    OS.Name = "Oversold";
    OS.DrawStyle = DRAWSTYLE_DASH;
    OS.PrimaryColor = RGB(128, 128, 128);
    Price.Name = "Price Type";
    Price.SetInputDataIndex(SC_LAST);
    Length.Name = "Period";
    Length.SetInt(20);
    Length.SetIntLimits(1, MAX_STUDY_LENGTH);
    Cutoff.Name = "Cutoff Period";
    Cutoff.SetInt(10);
    Cutoff.SetIntLimits(1, MAX_STUDY_LENGTH);
    Bars.Name = "Highpass filter length";
    Bars.SetInt(48);
    Bars.SetIntLimits(1, MAX_STUDY_LENGTH);
    return;
  OB[sc.Index] = .8;
  OS[sc.Index] = .2;
  //First calculate the Highpass Filter
  float alpha1 = (cos(sqrt(2) * 3.14159f / Bars.GetInt()) + sin(sqrt(2) * 3.14159f / Bars.GetInt()) - 1) / cos(sqrt(2) * 3.14159f / Bars.GetInt());
  HP[sc.Index] = (1 - alpha1 / 2) * (1 - alpha1 / 2) * (sc.BaseDataIn[Price.GetInputDataIndex()][sc.Index] - 2 * sc.BaseDataIn[Price.GetInputDataIndex()][sc.Index - 1] +
    sc.BaseDataIn[Price.GetInputDataIndex()][sc.Index - 2]) + 2 * (1 - alpha1) * HP[sc.Index - 1] - (1 - alpha1) * (1 - alpha1) * HP[sc.Index - 2];
  //Smooth the HighPass With Super Smoother
  float a1, c1, c2, c3;
  a1 = exp(-3.14159f * sqrt(2) / Cutoff.GetInt());
  c2 = 2 * a1 * cos(sqrt(2) * 3.14159f / Cutoff.GetInt());
  c3 = -a1 * a1;
  c1 = 1 - c2 - c3;
  //Calculate and plot the Stochastic
[2017-02-15 17:51:04]
The problem is not this:
This means Not a Number and it may be the result of a divide by zero.
Refer to:
https://en.wikipedia.org/wiki/Division_by_zero#Computer_arithmetic
