Date/Time: Sun, 12 Jan 2025 11:06:11 +0000
20 Month of Volume Profil
View Count: 718
[2017-02-15 10:45:14]
isa74 - Posts: 54
Sir,
I would like to load 20 months of datas in a specific chartbook with Market profils.
I observe that it seems impossible to load so many days.
The data range begins by 2016-06-20 and I cannot specifiy another date before when I selected Historical Chart.
When I input 20 in the Historical Chart Bar Period, the first date in the Data Range does not change.
I have also attached another image which is screenshot from the Marketscope interface: 20 Months of Volume profils on a 30mn chart.
Here is what i would like to get.
Last thing the point n°6 of your help documentation relates about a feature which seems not to be accessible anymore:
6.For the case of a chart window, in the Sierra Chart software select Edit >> Screen Images >> Upload Chart.
Do not see any voice menu named Screen Images.
Thanks for your help.
imagesc_sierracharts_interface_chart-settings_data-range.png / V - Attached On 2017-02-15 10:39:45 UTC - Size: 39.8 KB - 229 views
imagesc_marketscope_interface_Vbp_20Months_30Mn.png / V - Attached On 2017-02-15 10:41:39 UTC - Size: 600.07 KB - 236 views
[2017-02-15 18:23:04]
You are working with a futures contract chart. Therefore, to load more data in you need to use the Continuous Futures Contract feature:
http://www.sierrachart.com/index.php?page=doc/ContinuousFuturesContractCharts.html
[2017-02-16 13:34:34]
isa74 - Posts: 54
Sir,
If I activate this option, then I get a black background with the mention: Downloding Continuous Contract Data
It is 10 minutes like that now... I am on the Dax...
Is this normal ?
Thanks !
[2017-02-16 17:52:19]
That is a long time. It should not take that long but maybe your Internet connection is not fast enough.
You can monitor the progress of the historical data downloading through the Message Log:
http://www.sierrachart.com/index.php?page=doc/MessageLog.html
