Date/Time: Sun, 12 Jan 2025 09:40:42 +0000
session times keep reseting when i switch symbols
View Count: 908
[2017-02-15 06:31:22] |
User797603 - Posts: 29 |
I have the same session times for pit and evening times for all futures, but when i go to switch between ES and NQ for instance it resets the session times to 00:00 to 23:59. https://froelibt.tinytake.com/sf/MTM0MDI5N180OTI4MzA4 that address will show a screen shot of my settings and you can see. there must be something to save these settings for when i switch assets the same times will be there |
[2017-02-15 07:46:20] |
This section here explains how to prevent this: Global Symbol Settings: Setting of Intraday Chart Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
