Date/Time: Fri, 31 Jan 2025 15:41:03 +0000
How to customize alert sounds
View Count: 3911
[2017-02-15 01:11:24] |
User687828 - Posts: 17 |
Hello, how do I customize Alerts to play my own sound wav files?
[2017-02-15 04:33:43] |
This is explained here: https://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#AlertSoundSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-05-17 01:43:00] |
User792578 - Posts: 9 |
hi. maybe you can help me. I read all the explanation above on how can I create a audio alert on many variables(numbers) but I didn't found how can I create a audio alert when the color of my indicator is change . for example: I am using "sidewinder" indicator and I want to get sound alarm when the color is changes from green to red or opposite . please advice. thanks amit |
[2019-05-17 15:45:06] |
John - SC Support - Posts: 37622 |
You need to create an Alert based on the underlying reason why the indicator is changing color. You cannot build an alert based on the color change itself. For example, if the color is Green when ID1.SG1 is Greater than 10 and Red when it is Less than 10, and you want an alert when the study is Green, then you would need to create an alert that reads =ID1.SG1 > 10. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-05-17 16:38:43] |
Also refer to: Study/Chart Alerts And Scanning: Writing Formulas for Studies without Obvious Values Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
