Date/Time: Sun, 12 Jan 2025 09:34:36 +0000
Formula for alert that holds for a period of time
View Count: 586
[2017-02-14 20:43:45] |
Leif - Posts: 9 |
Hi, One of my alerts occasionally will flash for a second then disappear. I want to do an intrabar alert and not on bar close. But I want the alert to remain for awhile for confirmation. Is there a formula that will trigger my signal when the alert holds for at least 15 seconds? Thanks |
[2017-02-14 21:09:21] |
No. You really need to use ACSIL for something like this: Advanced Custom Study Interface and Language (ACSIL) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
