Date/Time: Sun, 12 Jan 2025 09:57:32 +0000
Bollinger Bands moving positon depending on the width of the chart
View Count: 693
[2017-02-14 16:48:06]
User40520 - Posts: 62
I have two intraday charts with the same number of trades per bar. On one chart the bands stay in place when the chart is stretched across the screen while on the other chart the bands move depending on the width. I tried changing the number of days from 30 to 360 on both charts and restarting SC but I get the same problem.
So on one chart I get BB support while on another same value/time frame chart it depends on how wide I make the chart as to where Bollinger Band S&R is. I have checked the BB settings are exactly the same. Other indicators are different on each chart - can this interfere?
Any suggestions how to correct this?
[2017-02-14 17:24:20]
Make sure the Scale Range of that study is set to Automatic. Refer to:
http://www.sierrachart.com/index.php?page=doc/Scaling.html#ScaleWindowStudy
