Date/Time: Sun, 12 Jan 2025 09:55:24 +0000
Time based bars-candles skipped
View Count: 666
[2017-02-14 14:12:52] |
User307319 - Posts: 41 |
Dear Sierra chart, I have my chart of 4 seconds and it is happening some time that the few candles are skipped. For example it happened this morning again : - 09.02.12 the candle bar price is 2325.00 http://www.sierrachart.com/image.php?Image=1487081476519.png - the next candle is at 09.02.28 price is 2324.75-2324.50 http://www.sierrachart.com/image.php?Image=1487081424760.png But between 12 and 28 should be 2 more candles , at 09.02.16, 09.02.20, which has not appeared. Please advise. Thank you |
[2017-02-14 17:00:57] |
Refer to help topic 7.6 about this: http://www.sierrachart.com/index.php?page=doc/HistoricalIntradayData.html#h7.6 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
