Date/Time: Mon, 12 Oct 2026 14:31:29 +0000
[Programming Help] - Custom Chart and Historical Market Depth Historical Graph
View Count: 2763
[2017-02-14 13:46:11]
User64410 - Posts: 14
I have developed custom chart based on -BID_ASK_TRADE_SYNC data. Chart works quite fine and do exactly what I need. But I have discovered:
I actualize Last but there is no "white box" showing actual Last price on Y axis.
I'm not able to attach Market Depth Historical Graph to this chart. What do I need to change to solve this? If I try to attach Market Depth Historical Graph Message Log shows:
"Custom DLL Study DateTime: Out of bounds array error at Index 7866 (it looks like last Index).
How can I solve this?
Thank you.
SCSFExport scsf_MyCustom(SCStudyInterfaceRef sc)
  SCSubgraphRef Open = sc.Subgraph[0];
  SCSubgraphRef High = sc.Subgraph[1];
  SCSubgraphRef Low = sc.Subgraph[2];
  SCSubgraphRef Last = sc.Subgraph[3];
  if (sc.SetDefaults) {
    // Set the defaults
    sc.GraphName = "My Graph";
    sc.AutoLoop = 1;
    sc.IsCustomChart = 1; // true
    sc.GraphRegion = 0; // First region
    sc.DrawZeros = 0; // false
    sc.StandardChartHeader = 1; // true
    sc.DrawZeros = 0;
    sc.FreeDLL = 1;
    // HIGH/LOW subgraf:
    High.Name = "High";
    High.DrawStyle = DRAWSTYLE_STAIR;
    High.PrimaryColor = RGB(70, 70, 70);
    Low.Name = "Low";
    Low.DrawStyle = DRAWSTYLE_STAIR;
    Low.PrimaryColor = RGB(70, 70, 70);
    Last.Name = "Last";
    Last.DrawStyle = DRAWSTYLE_STAIR;
    Open.Name = "Open";
    Open.DrawStyle = DRAWSTYLE_IGNORE;
    Open.PrimaryColor = RGB(70, 70, 70);
    // inputs:
    sc.Input[0].Name = "pouze vetsi nez";
    sc.Input[0].SetInt(0);
    return;
  if (sc.UpdateStartIndex == 0){
    sc.ResizeArrays(1);
  // persist vars:
  int& k = sc.GetPersistentInt(0);
  int& idx = sc.GetPersistentInt(1);
  // first values:
  if (sc.Index == 0){
    sc.DateTimeOut[0] = sc.BaseDateTimeIn[sc.Index];
    Open[0] = sc.BaseDataIn[0][sc.Index];
    Low[0] = sc.BaseDataIn[2][sc.Index];
    High[0] = sc.BaseDataIn[1][sc.Index];
    Last[0] = sc.BaseDataIn[3][sc.Index];
    idx = 0;
  // actualization:
  if (sc.Index > 0) {
    sc.DateTimeOut[idx] = sc.BaseDateTimeIn[sc.Index];
    Open[idx] = sc.BaseDataIn[0][sc.Index];
    Low[idx] = sc.BaseDataIn[2][sc.Index];
    High[idx] = sc.BaseDataIn[1][sc.Index];
    Last[idx] = sc.BaseDataIn[3][sc.Index];
    Last.DataColor[idx] = sc.Input[10].GetColor();
  // new bar condition:
  if () {
    // add bar:
    sc.AddElements(1);
    // ++ custom index for next use:
    idx++;
    // reset other persist vars:
    k = 0;
Date Time Of Last Edit: 2017-02-14 13:54:17
attachmentcustom.cpp - Attached On 2017-02-14 13:52:15 UTC - Size: 1.85 KB - 555 views
[2017-02-14 18:00:03]
You cannot use the Market Depth Historical Graph study on a custom ACSIL chart.
[2017-02-15 09:58:01]
Are you sure? I tried to apply Market Depth Historical Graph to your example of custom chart called Copy of Base Graph and it works fine.
In my custom chart i got in to situation, when Market Depth Graph is not fixed to price (screen attached). There is no error in message log after sc.GraphDrawType = GDT_OHLCBAR. You have no advice what should be missing to fix that Market depth Graph to actual price?
imageSnímek obrazovky 2017-02-15 v 10.57.13.png / V - Attached On 2017-02-15 09:57:32 UTC - Size: 235.52 KB - 579 views
[2017-02-15 18:03:42]
Make sure the Scale Range for all of the studies in Chart Region 1 are set to Automatic:
http://www.sierrachart.com/index.php?page=doc/Scaling.html#ScaleWindowStudy
[2021-12-07 21:08:50]
rread - Posts: 10
Is it still the case that one cannot use the Market Depth study on a custom chart or is there a method to do this? The suggestion to use the Automatic scale range seems to imply it may be possible?
