Date/Time: Sun, 12 Jan 2025 09:22:30 +0000
ZNH17 ZNM17 Daily Data Problem
View Count: 687
[2017-02-14 13:17:28] |
ticinotrader - Posts: 397 |
I have some problems with the Daily bars data with ZN (10yr Notes) as shown on the image below. There is a bad tick on the chart in the last bar on the historical daily chart (14/02/2017). I am connected to SC Data ad using the latest 1519 version. I tried to delete and re-download the data but the result is the same. I have the issue on ZNH17 and ZNM17 daily charts. Can you please let me know how can I correct them? Thank you! http://www.sierrachart.com/image.php?Image=1487077912634.png Update: I have tried numerous other symbols now (forex and futures symbols historical daily charts with the SC Data) and having the same issue on all of them. Date Time Of Last Edit: 2017-02-14 13:21:02
[2017-02-14 16:38:49] |
This is an issue with version 1519 which has been removed. Use the current version 1518. Follow the instructions here: http://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
