Date/Time: Sun, 12 Jan 2025 09:38:52 +0000
Data Connection Failure
View Count: 601
[2017-02-14 12:26:50] |
KrisM2M - Posts: 6 |
Hello, I'm receiving this message when I attempt to connect to me CQG Fix Trading connection. This issue started Friday afternoon and has persisted thru today. I was able to connect with no issue Friday morning. Screenshot attached. Is this a Sierra issue or a CQG issue? Thanks, Kris |
Error - Message Log.jpg / V - Attached On 2017-02-14 12:25:58 UTC - Size: 157.5 KB - 225 views |
[2017-02-14 16:36:27] |
This is a CQG error message. Refer to: http://www.sierrachart.com/index.php?page=doc/CQGTrading.php#CommonErrorMessages Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
