Date/Time: Sun, 12 Jan 2025 09:29:01 +0000
V 1519
View Count: 739
[2017-02-14 11:31:22]
ertrader - Posts: 681
Hi Support...just updated to v1519..now getting the following errors. I deleted all data and downloaded but data was incorrect.
I went back to v1518 and deleted all data and downloaded and everything is back to normal.
Can you take a look?
http://www.sierrachart.com/image.php?Image=1487071829249.png
Error filtered for YM-201703-ECBOT, Intraday High = 10633.500000, Intraday Low = 10633.000000, Value = 5332.000000, Time Difference = 9 seconds, Percentage = 10.900000% | 2017-02-14 06:20:52
Error filtered for GBL-201703-DTB, Daily High = 10632.500000, Daily Low = 163.699997, Value = 12303.000000, Time Difference = 1 seconds, Percentage = 10.099999% | 2017-02-14 06:20:52
Error filtered for NQ-201703-GLOBEX, Intraday High = 53.329998, Intraday Low = 53.320000, Value = 5258.500000, Time Difference = 49 seconds, Percentage = 149.000000% | 2017-02-14 06:20:52
Error filtered for CL-201703-NYMEX, Intraday High = 163.759995, Intraday Low = 163.750000, Value = 53.309998, Time Difference = 17 seconds, Percentage = 58.499996% | 2017-02-14 06:20:53
Error filtered for CL-201703-NYMEX, Intraday High = 163.759995, Intraday Low = 163.750000, Value = 53.309998, Time Difference = 18 seconds, Percentage = 59.000004% | 2017-02-14 06:20:53
Error filtered for NQ-201703-GLOBEX, Daily High = 5261.000000, Daily Low = 5252.250000, Value = 106.329994, Time Difference = 2 seconds, Percentage = 10.200000% | 2017-02-14 06:20:55
Error filtered for NQ-201703-GLOBEX, Daily High = 5261.000000, Daily Low = 5252.250000, Value = 106.334999, Time Difference = 2 seconds, Percentage = 10.200000% | 2017-02-14 06:20:55
Error filtered for ES-201703-GLOBEX, Intraday High = 53.320000, Intraday Low = 53.309998, Value = 2325.500000, Time Difference = 24 seconds, Percentage = 124.000000% | 2017-02-14 06:20:56
Error filtered for YM-201703-ECBOT, Intraday High = 10633.500000, Intraday Low = 10633.000000, Value = 20375.000000, Time Difference = 19 seconds, Percentage = 11.900000% | 2017-02-14 06:21:01
Error filtered for ES-201703-GLOBEX, Daily High = 2327.500000, Daily Low = 2323.250000, Value = 106.329994, Time Difference = 7 seconds, Percentage = 10.699999% | 2017-02-14 06:21:02
Error filtered for ES-201703-GLOBEX, Daily High = 2327.500000, Daily Low = 2323.250000, Value = 106.329994, Time Difference = 9 seconds, Percentage = 10.900000% | 2017-02-14 06:21:05
Error filtered for NQ-201703-GLOBEX, Daily High = 5261.000000, Daily Low = 5252.250000, Value = 123.040001, Time Difference = 14 seconds, Percentage = 11.400000% | 2017-02-14 06:21:07
Error filtered for NQ-201703-GLOBEX, Intraday High = 53.329998, Intraday Low = 53.320000, Value = 5258.500000, Time Difference = 63 seconds, Percentage = 163.000000% | 2017-02-14 06:21:07
[2017-02-14 11:38:07]
there were many more errors...this was just a sample
[2017-02-14 12:56:34]
Outlander - Posts: 91
I had the same problem and had to role back to the older version. n
[2017-02-14 15:53:09]
We have removed version 1519 for now. There is a problem with it due to recent changes. This is only a prerelease. Data for one symbol is being mapped to another symbol under certain conditions.
Go back to version 1518 and then re-download the data with errors or the missing data by following the instructions here:
https://www.sierrachart.com/index.php?page=doc/helpdetails2.html#h2.1.2
