Date/Time: Sun, 12 Jan 2025 09:56:53 +0000
hello
View Count: 575
[2017-02-14 09:31:58] |
User166767 - Posts: 32 |
why your candle chart is different with cmegroup website.if it is this ,how can I believe your chart is standard ?I see the cmegroup website m6ah2017 one minute candle ,your chart is not identical with the cmegroup m6ah2017 one minute candle ,can you tell me the reason?I need the standard chart ,and the identical chart with cmegroup chart. |
[2017-02-14 17:54:31] |
You need to provide an image of the chart by following these instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image And then tell us the Date and Time and time zone of the specific issue. And you need to tell us specifically the data you are seeing on the CME Group website. You also need to understand that the data you are seeing is not from Sierra Chart but from CQG in this case. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
