Date/Time: Sun, 12 Jan 2025 09:30:21 +0000
Daily Net Change
View Count: 640
[2017-02-14 08:59:32] |
GPST10 - Posts: 139 |
Hello, I'm looking for Net Change (% change) number to be able to put on chart as stationary text. Is there any study for that or any way to achieve except programming, unless somebody can do that for me as a business. Thks |
[2017-02-14 16:39:49] |
You can add this through the Chart Header: http://www.sierrachart.com/index.php?page=doc/WorkingWithCharts.html#RegionDataLine Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
