Date/Time: Sun, 12 Jan 2025 09:44:05 +0000
Working Off-Line - error message in v1518
View Count: 784
[2017-02-13 22:15:20] |
User264623 - Posts: 28 |
Installed release 1518 a few days ago. Now getting the following error message in the message log every 2 minutes when working off-line. Error getting address info for www.sierrachart.com. Windows error code 11001: No such host is known. | 2017-02-13 16:37:20 *
Error getting address info for www.sierrachart.com. Windows error code 11001: No such host is known. | 2017-02-13 16:39:20 * Error getting address info for www.sierrachart.com. Windows error code 11001: No such host is known. | 2017-02-13 16:41:20 * Error getting address info for www.sierrachart.com. Windows error code 11001: No such host is known. | 2017-02-13 16:43:20 * Error getting address info for www.sierrachart.com. Windows error code 11001: No such host is known. | 2017-02-13 16:45:20 * Using Sierra Chart with data disconnected, and no internet connection triggers the message. Using SC with data disconnected, but with internet connection - the message doesn't trigger. |
[2017-02-13 22:27:58] |
This will be solved in the next release.
