Date/Time: Sun, 12 Jan 2025 09:31:24 +0000
OCO issue
View Count: 730
[2017-02-13 15:08:25]
User100997 - Posts: 3
Hi SC,
When trading with an OCO bracket, the order has issues if it is adjusted before the fill; with multiple contracts.
For example, if I set a bracket order of 10 tick stop and 10 tick target, and adjust the 10 tick stop to 5 ticks before the order is filled, the stop order is split once it is filled. Meaning instead of the full OCO stop being adjusted to how I wanted it, it is only partially adjusted.
And when I go to merge the 2 stops after the order is filled, I receive an error message.
Is there anyway to resolve this? Wanted to check before using my real account via your platform.
attached is an example from today.
Thank you
imageafter the fill.jpg / V - Attached On 2017-02-13 15:06:10 UTC - Size: 247.99 KB - 208 views
imageerror msg.jpg / V - Attached On 2017-02-13 15:06:45 UTC - Size: 98.64 KB - 233 views
[2017-02-13 17:22:52]
You are running an older version of Sierra Chart. This issue has already been resolved.
Update following the instructions here:
http://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate
