Date/Time: Sun, 12 Jan 2025 09:23:04 +0000
acsil subgraph drawstyle fill top & bottom
View Count: 719
[2017-02-13 14:01:48] |
vrunrun - Posts: 53 |
Hi SC, Using ACSIL, is it possible to use top and bottom drawstyle on more than 2 subgraphs? If I had 4 subgraphs and tried to use the same top and bottom style on both pairs, it failed. Then, I tried to use different top and bottom styles on each pair and it still failed. Any suggestion? |
[2017-02-13 17:56:18] |
Yes definitely this is supported. This is from the documentation: It is supported to use multiple sets of the Top and Bottom Draw Style Pairs within a single study. The first encountered Top/Bottom Draw Style will be matched with the next found matching Top/Bottom Draw Style in the list of Subgraphs according to the order of the Subgraphs. The same logic continues for the remaining Top and Bottom Draw Style pairs.
Also we do not know what is meant by "failed". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
