Date/Time: Wed, 09 Sep 2026 05:06:59 +0000
Problem for linking two CPPs with an .H and compiling it
View Count: 1117
[2017-02-13 10:10:57]
User210074 - Posts: 63
Hello, I have an error message below. I do not know how to compile the 2 CPPs in DLL without this error
Test.cpp
#include <iostream>
#include <string>
#include "Root.h"
#include "sierrachart.h"
using namespace std;
SCDLLName("Test")
SCSFExport scsf_Test(SCStudyInterfaceRef sc) {
SCSubgraphRef Red = sc.Subgraph[0];
if (sc.SetDefaults){
    sc.GraphName = "Test 2 CPP";
    sc.GraphRegion = 0;
    sc.AutoLoop = true;
sc.FreeDLL = 1;
    Red.Name= "Red";
    Red.DrawStyle = DRAWSTYLE_VALUE_ON_HIGH;
    Red.LineWidth = 1;
    Red.PrimaryColor = RGB(0,128,255);
    Red.DrawZeros = true;
    return;
   }//End defaults
double A = 2.0f;
double B = 3.0f;
double C = 4.0f;
double D = 5.0f;
double E = 6.0f;
double F = 7.0f;
Mem(A, B, C, D, E, F);
Red[sc.Index]=Mem;
}//End Function
Root.h
#ifndef Root_H_INCLUDED
#define Root_H_INCLUDED
double Mem(double Z, double Y, double X, double W, double V, double U);
#endif // Root_H_INCLUDED
Mem.cpp
#include <iostream>
#include <vector>
#include <string>
#include "Routeur.h"
SCDLLName("Mem")
SCSFExport scsf_Mem(SCStudyInterfaceRef sc) {
if (sc.SetDefaults){return;}//end of defaults
double Mem(double Z, double Y, double X, double W, double V, double U){
int const Size(5);
int const Ini(0);
vector <int> MemTab(Size);
MemTab[Z] = Ini;
MemTab[Y] = Ini;
MemTab[X] = Ini;
MemTab[W] = Ini;
MemTab[V] = Ini;
MemTab[U] = Ini;
auto ResA = std::find(std::begin(MemTab), std::end(MemTab), Ini);
if(ResA != std::end(MemTab)){return Size;}
else{return Ini;}
}//End of Mem
}//End of Function
Error
C:\WINDOWS\system32\cmd.exe /C "C:\SierraChart\ACS_Source\VisualCCompile.Bat"
C:\SierraChart\ACS_Source>call "C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\vcvarsall.bat"
Test.cpp
C:\SierraChart\ACS_Source\Test.cpp(28): error C2440: '=': cannot convert from 'double (__cdecl *)(double,double,double,double,double,double)' to 'float'
C:\SierraChart\ACS_Source\Test.cpp(28): note: There is no context in which this conversion is possible
-- End of Build -- 10:59:00
[2017-02-13 10:20:06]
Oops I forget the good libraries
Test.cpp
#include <windows.h>
#include <math.h>
#include <iostream>
#include <stdio.h>
#include <string.h>
#include <vector>
#include <iomanip>
#include <algorithm>
#include <iterator>
SCDLLName("Test")
    sc.GraphRegion = 0;
    sc.AutoLoop = true;
sc.FreeDLL = 1;
    Red.Name= "Red";
    Red.LineWidth = 1;
    return;
   }//End defaults
double A = 2.0f;
double B = 3.0f;
double C = 4.0f;
double D = 5.0f;
double E = 6.0f;
double F = 7.0f;
Red[sc.Index]=Mem;
}//End Function
error
Test.cpp
C:\SierraChart\ACS_Source\Test.cpp(33): error C3861: 'Mem': identifier not found
C:\SierraChart\ACS_Source\Test.cpp(34): error C2065: 'Mem': undeclared identifier
-- End of Build -- 11:16:51
[2017-02-13 10:22:18]
The problem is you have defined a function within a function.
You cannot do that.
You have done this in the Mem.cpp file.
Date Time Of Last Edit: 2017-02-13 10:22:36
