Date/Time: Sun, 12 Jan 2025 09:47:00 +0000
Continuous Contract Rollover
View Count: 758
[2017-02-12 22:54:26] |
User788311 - Posts: 29 |
Hello, would you help? I backest the NQ on 2min. charts using numbers bars. What type of continuous contract rollover settings should I use to be the most accurate with the historical data? 1. Date rule rollover 2. Volume based rollover 3. Date rule rollover, back adjusted 4. Volume based rollover, back adjusted Thank you, Richard |
[2017-02-12 23:19:36] |
