Date/Time: Sun, 12 Jan 2025 09:36:04 +0000
'sc' was not declared in this scope sc.UseTool(Line01);
View Count: 873
[2017-02-12 17:42:12] |
User53601 - Posts: 105 |
Hello, In the definition of a function I use the sc.UseTool. Build Output gives me this error: error: 'sc' was not declared in this scope sc.UseTool(Line01); Could you help with this? thank you |
[2017-02-12 20:54:43] |
Refer to this section here for how to do this: ACSIL Programming Concepts: Passing ACSIL Interface Members Structure To Secondary Function Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
