Date/Time: Sun, 12 Jan 2025 10:56:59 +0000
use color of zigzag volume as filter
View Count: 1389
[2017-02-11 04:23:01]
User970210 - Posts: 88
Hi, since zigzag value can be zero or no change from bar to bar after trend change, I would like just use color of the indicator as filter for trigger signals. Is this possible? thanks
[2017-02-12 09:10:50]
You can only use the values of the study Subgraphs. Refer to:
Study/Chart Alerts And Scanning: Writing Formulas for Studies without Obvious Values
[2017-02-14 18:32:03]
JayShea - Posts: 92
Bring up a Spreadsheet and look at the columns. You'll figure out something. I did a year ago when it interested me until all the rewriting became un-nerving. I don't recall what formulas I used but it's there.
JD
[2017-02-15 23:29:04]
@JayShea. thanks. how do you output indicator value to spreadsheet in sierra chart?
[2017-02-15 23:54:42]
JayShea - Posts: 92
I really don't use spreadsheets any more due to deciding if I needed a signal that complex requiring a spreadsheet, I'd be better with something simple.
Long way of saying I don't understand the question. Indicator values are automatically provided when a SS is opened. Glad to help but need clarification.
Cheers
JD
[2017-02-16 17:31:36]
Here are the instructions to use the Spreadsheet Study:
http://www.sierrachart.com/index.php?page=doc/OverviewOfSpreadsheetStudies.php
In the case of the Zig Zag study you will need to set the Additional Output for Spreadsheets Input to Yes to see the additional columns of data on the Sheet.
