Date/Time: Sun, 12 Jan 2025 09:33:59 +0000
Volume At Price Threshold v2
View Count: 1164
[2017-02-10 21:21:10] |
CAudler - Posts: 3 |
Hi, I am trying to show the alert/square when the bid ask is greater than 500% of each other. However, I can't get it to show if say the bid amount was 50 and the offer was 0. In other words, levels that contain a 0 do not trigger the alert. Is there a way to enable the alerts even if a 0 is there? My second question would be, How do you change ALL of the alert styles/colors at once. Changing them 1 by 1 is very painful!!! |
[2017-02-11 23:17:05] |
What is the Comparison Method Study Input set to? My second question would be, How do you change ALL of the alert styles/colors at once. Changing them 1 by 1 is very painful!!! Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-12 01:15:33] |
Comparison method is set to Ask Volume / Bid VOlume difference. Setting the volume threshold to 0 doesn't help, I still can't get the squares to show up if say the bid volume is 0 and ask volume is 10 with a 500% threshold or 1000% threshold. Either of those should work. |
[2017-02-13 19:13:00] |
A percent difference calculation is undefined when the initial value is zero. This is why currently the result is zero. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-02-13 19:14:05
