Date/Time: Sun, 12 Jan 2025 09:17:28 +0000
View Count: 829
[2017-02-10 14:12:29] |
User850017 - Posts: 41 |
Where is a problem? My account to use only me. Can you reset this?
Attachment Deleted. |
[2017-02-10 16:29:41] |
You are able to login from 2 systems at a time. We show that you are not currently logged in. This time you should have no trouble logging from 2 systems at a time. Did you need to login from more systems than that? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-02-10 16:30:25
