Date/Time: Sun, 12 Jan 2025 09:53:48 +0000
Remove Volume Profile Drawing Tool using ACSIL
View Count: 900
[2017-02-10 13:40:50] |
Marmany - Posts: 307 |
When a Volume by Price Study has been drawn using the Volume Profile Drawing tool it is not removed with sc.DeleteUserDrawnACSDrawing,(coding is correct as other types of drawings removed) Tools>> Erase All Drawn Volume Profiles is one way to remove. Is it possible to achieve this with an ACSIL function? Please advise. |
[2017-02-10 17:24:40] |
No. The implementation of this is too complex.
