Date/Time: Sun, 12 Jan 2025 09:27:08 +0000
Windows XP Support Discontinued
View Count: 955
[2017-02-10 06:15:25]
As of approximately version 1510, Sierra Chart is no longer compatible with Windows XP.
There are functions being used which are not supported on Windows XP and the generated executable is just not compatible with Windows XP.
If you are using Windows XP, let us know and we will provide you instructions to use an earlier version of Sierra Chart.
Date Time Of Last Edit: 2017-02-10 06:16:05
[2017-02-13 17:55:52]
infpz - Posts: 826
Hello, please send instructions. -PZ
[2017-02-13 18:37:57]
This is the installer that needs to be used for Windows XP:
https://www.sierrachart.com/downloads/SierraChartFileDownloader_WindowsXP.exe
And they will want to install version 1504 or earlier. How to do that is explained here:
http://www.sierrachart.com/index.php?page=doc/download.php#Rollback
If there are any problems, let us know. Version 1504 should work with Windows XP but if there is a problem let us know.
