Date/Time: Sun, 12 Jan 2025 09:32:37 +0000
Is Accumulated Volume study/indicator available?
View Count: 2449
[2017-02-10 04:39:53] |
User837624 - Posts: 17 |
Hi, I watched a webinar today on using Order Flow and the presenter was using Sierra Charts 1504 and he had an indicator called "Accumulated Volume" shown below a chart (instead of a normal volume) and he said it was a standard one on Sierra. I don;t see anything like this on the list of studies that I can add to the chart or on the list of technical studies on your site. I wonder if this is available? (I'm using an older version but the list on your site is probably up to date?) You have "Cumulative Delta Bars - Volume" study that appears to be similar in what it does, but it is different in its display. The "Accumulated Volume" was showing a sequence of progressively taller green bars while the trend was up and then started with small and growing red bars after the trend has turned. Please see the screenshot attached. Regards, Andrei |
AccumultedVolume Study.png / V - Attached On 2017-02-10 04:37:51 UTC - Size: 191.64 KB - 919 views |
[2017-02-10 06:04:39] |
See: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s341 (Zig Zag Cumulative Volume) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
