Date/Time: Sun, 12 Jan 2025 09:58:27 +0000
sharing data from a newer version to an older Spreadsheats version
View Count: 747
[2017-02-10 00:36:56] |
JordiE - Posts: 38 |
Hi Support Team, good envening...! I hope you're fine. Like the title says, is it possible to share DATA folder and/or *.scid and *.dly files between two SC instances, running at the same time, one NEW Spreadsheats and one OLD kind ? Many thanks in advance for your reply. Best regards Jordi |
[2017-02-10 04:32:04] |
Yes. This can be done by sharing chart data files. Refer to: https://www.sierrachart.com/index.php?page=doc/FileMenu.html#FileFindSymbol_OpenChartFromAnotherInstance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-10 09:11:12] |
Thank you so much, Support Team for your quick answer ! Have a nice day ! Best regards Jordi |
