Date/Time: Sun, 12 Jan 2025 09:43:26 +0000
fwiw 1517
View Count: 780
[2017-02-09 19:38:20] |
User20450 - Posts: 330 |
i tired it just to see if support link was fixed and like magic it is fixed on 1517 , 2 others in my room report same as well too , so we thank you for that !!!
[2017-02-09 20:11:37] |
We changed nothing in relation to this.
[2017-02-10 13:48:33] |
i understand but it works fine now is all im saying , thank you
[2017-02-10 16:58:09] |
The only thing that is conceivable is we removed a compiler flag relating to support for Windows XP. Why this would matter, we do not know. Sierra Chart makes one very simple call to the operating system ShellExecute command to navigate to a website URL. As we said that has not been touched since 2013. We did not have any other reports of a problem like this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
