Date/Time: Sun, 12 Jan 2025 09:33:17 +0000
ACS - error messages
View Count: 618
[2017-02-09 19:05:12] |
jizzary - Posts: 177 |
can u pls explain the error messages ? is there any web page explaining all kind of errors ? |
[2017-02-09 20:21:33] |
Windows error code 8 is from the Windows operating system. You can run an Internet search for that. The array is unallocated error is harmless. If it occurs with Sierra Chart built-in studies we can analyze the cause of it and resolve it. Otherwise just ignore it. For help with the unhandled exception, refer to help topic 17: Sierra Chart Unexpectedly Shutting Down | Memory Errors | Unusual Software Problems | Exception Errors | Freezing of User Interface Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
