Date/Time: Sun, 12 Jan 2025 09:38:14 +0000
extending price cursor line
View Count: 666
[2017-02-09 15:40:12] |
User780238 - Posts: 45 |
The price cursor (dotted line) floats on the chart on whole page but stops short from vertical price scale. How can I extend this line to go closer to the vertical scale. thanks |
screenshot.jpg / V - Attached On 2017-02-09 15:38:00 UTC - Size: 91.54 KB - 235 views Attachment Deleted. |
[2017-02-09 18:06:59] |
The only way we can help you is if you tell us the exact name of the study you are using. We assume you are using a study? Also when posting an image of a chart, only use this method documented here and no other: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-09 19:23:27] |
Following are the studies: Current price line VbP-idays Number bars number bars calculated color background based on alert condition |
[2017-02-09 20:17:49] |
With the Current Price Line study you can set the Forward Project Current Price Line Input to Yes.
