Date/Time: Sun, 12 Jan 2025 09:22:37 +0000
duplicate chartbook issue
View Count: 619
[2017-02-09 12:42:51] |
User514370 - Posts: 62 |
Just hit small issue during duplicating chartbook with drawing tools (I´m using rectangles, lines, etc.) - the positions in the duplicated chartbook (either in the chart or studies) is changed, they are a little bit off the original position. Please, let me know, if it´s an issue or it´s my fault. Thank you. |
[2017-02-09 17:59:20] |
How are you duplicating a Chartbook? And we need a very precise example to be able to understand what you are saying. Provide an image of the chart, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image And only provide us one example and no other. Only one example. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
