Date/Time: Sun, 12 Jan 2025 09:20:24 +0000
Issue with Horizontal Line at Time
View Count: 655
[2017-02-09 10:02:22] |
User50927 - Posts: 91 |
Using the S&P 500 e-mini futures contract, when I set the start time to 16:00:00 and the stop time 09:29:59 in order to plot a horizontal line that spans the overnight session from the previous-day close to the New York open the following day, the study blows pass the stop time and plots a 24h line from 16:00:00 the previous day to 16:00:00 the next day. That happened whether the "Limit Horizontal Line From time 1 Day" is set to "No" or "Yes". I then was able to determine that the start-stop time in the study is programmed to work only with intraday times inside a 24h cycle. So my question is: Would it be possible to make the start-stop time in the study work like the start-end time in Chart Settings, which can read continuously pass 23:59:59 and into any pre-set end time the following day, such as 16:00:00-15:00:00? Thank you. |
[2017-02-09 17:49:40] |
We will look into this.
