Date/Time: Sun, 12 Jan 2025 09:33:50 +0000
Is it possible to see full buy and sell order columns on the DOM when using chart replay ?
View Count: 1192
[2017-02-08 20:34:17]
User48557 - Posts: 138
As you can see in the image i attached, The dom is only showing price and 1 buy and sell column on each side. When I back test levels I am unable to see the standard 10 buy and sell columns on each side and the amount of orders sitting at each level. When I trade live it shows all the orders but not back testing. Is there a package or data service I can buy so when I play the charts on replay I can see the 10 orders on each side? So it looks like the second image (dom2)
imagedom.PNG / V - Attached On 2017-02-08 20:29:02 UTC - Size: 125.78 KB - 290 views
imagedom2.PNG / V - Attached On 2017-02-08 20:33:19 UTC - Size: 36.91 KB - 271 views
[2017-02-09 05:28:56]
You need to follow through the instructions here to do what you require:
http://www.sierrachart.com/index.php?page=doc/ReplayChart.html#ReplayingTradeDOM
[2017-02-09 11:56:07]
ok so where is the ''enable market dept data' ?
imagesc.PNG / V - Attached On 2017-02-09 11:56:00 UTC - Size: 185.5 KB - 271 views
[2017-02-09 17:57:50]
You are running an older version of Sierra Chart. Update following these instructions:
http://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate
We see you are running the version of Sierra Chart supporting Old Spreadsheets. So if you need to continue to use that version, then you cannot update.
[2017-02-09 19:40:17]
Ok so i downloaded the new version and I see the ''record market depth data'' . I clicked it and opened up a new dom chart. Then when I play replay I still don't see the market depth levels. What is going on?
imagedom3.PNG / V - Attached On 2017-02-09 19:37:22 UTC - Size: 151.02 KB - 256 views
[2017-02-09 20:12:45]
The market depth data will only be recorded as of the time the option has been enabled. There will be no market depth data recorded before that point in time.
[2017-02-10 01:15:53]
Rex1 - Posts: 14
in Replay mode, does the stacking and pulling data will show up on DOM as live mode does?
thanks
Rex.
[2017-02-10 03:07:06]
This is not yet supported but we expect will be coming in the next three months.
[2017-02-10 15:55:18]
Ok so i enabled ''record market depth data'' yesterday. Then today I scrolled back about 20 minutes of price action and played ''market replay'' As you can see I still don't see the 10 bid and ask levels on the dom . Why is it still not working ?
imagedom still not working.PNG / V - Attached On 2017-02-10 15:50:07 UTC - Size: 112.94 KB - 250 views
[2017-02-10 17:18:12]
Reconnect to the data feed after enabling that option:
http://www.sierrachart.com/index.php?page=doc/FileMenu.html#ProcedureToReconnect
We will make sure to update the documentation.
[2017-02-10 18:11:34]
Ok thanks it works now. Just one more follow up question. Does it only record the DOM for the time period I am connected to the data feed? I tried to replay from early this morning and it didn't give me any DOM levels. I noticed that from the time I was connected to the data feed I could see the DOM levels in replay. Is that how it works? Thanks
[2017-02-10 18:25:59]
The answer is yes. This does make sense.
