Date/Time: Sun, 12 Jan 2025 07:56:16 +0000
Last price in Y axis of chart
View Count: 699
[2017-02-08 17:16:38] |
User170575 - Posts: 221 |
Hello, Just wanted to see how to remove or disable it? Many thx, Cy |
[2017-02-08 18:22:33] |
You cannot. Other than change its color through Graphics Settings: Graphics Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
