Date/Time: Sun, 12 Jan 2025 07:50:47 +0000
Open 2 sierrachart accounts in the same computer
View Count: 680
[2017-02-08 16:51:32] |
User252419 - Posts: 235 |
Is it possible to open 2 accounts in the same computer? Thank you |
[2017-02-08 18:23:06] |
Refer to: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
