Date/Time: Sun, 12 Jan 2025 08:08:55 +0000
Chart Dom
View Count: 906
[2017-02-08 15:55:48] |
User771416 - Posts: 47 |
Is there anyway to add Stop-Limit order entry types to the chart DOM?
[2017-02-08 18:35:44] |
Refer to step 6 here for instructions for this: https://www.sierrachart.com/index.php?page=doc/ChartTrading.html#ChartDOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-08 19:00:40] |
Thanks for that. However, i made the change, then went back into Trade>Chart DOM Settings and i still don't see Stop-Limit as a choice in the drop downs. i still only see limit and stop types. Would i therefore select an order type of "Stop" in the Chart DOM and assume the system will then treat it as a Stop-Limit because i've made the selection in the global setting? |
[2017-02-08 19:11:48] |
In one of the paragraphs at step 6 it says: "To use Stop-Limit orders instead of Stop orders, enable Trade >> Open Trade Window for Chart >> Menu / M >> Use Stop-Limit Orders on Chart DOM on the chart or Trade DOM. " Review the documentation again. Would i therefore select an order type of "Stop" in the Chart DOM and assume the system will then treat it as a Stop-Limit because i've made the selection in the global setting? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
