Date/Time: Sun, 12 Jan 2025 08:02:54 +0000
Chart Settings Dialogue Box - Super Wide
View Count: 706
[2017-02-08 15:33:01] |
TapeReader - Posts: 89 |
When a chart's 'Chart Settings' dialogue box is launched...it consumes the entire width of a monitor and none of the fields are exposed. Is there a way to shrink this window to the normal size? Screenshot attached. Thanks, C |
Chart Settings WIndow - Super Wide.jpg / V - Attached On 2017-02-08 15:32:27 UTC - Size: 96.56 KB - 246 views |
[2017-02-08 17:45:09] |
This must be some kind of operating system issue. We recommend restarting the computer. Or reduce the number of programs running. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
