Date/Time: Sun, 12 Jan 2025 08:05:54 +0000
Second computer
View Count: 1042
[2017-02-08 07:37:08] |
User11010 - Posts: 7 |
Starting DTN IQ Feed interface software. | 2017-02-08 07:31:20 Error starting IQ Feed interface software. Error code: 2 | 2017-02-08 07:31:20 * IQFeed | Fully disconnected. | 2017-02-08 07:31:20 Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-02-08 07:31:20 IQFeed | Connecting. | 2017-02-08 07:34:20 IQ Feed: Failed to look up the port number for the Admin connection, using default port. | 2017-02-08 07:34:20 * IQFeed | Connecting to Admin port 9300 | 2017-02-08 07:34:20 Socket (36) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2017-02-08 07:34:21 Socket (36) | Shutdown and closed. | 2017-02-08 07:34:21 IQFeed | Disconnected from Admin port. | 2017-02-08 07:34:21 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-02-08 07:34:21 To prevent further connection attempts, select 'File >> Disconnect'. | 2017-02-08 07:34:21 Starting DTN IQ Feed interface software. | 2017-02-08 07:34:21 Error starting IQ Feed interface software. Error code: 2 | 2017-02-08 07:34:21 * IQFeed | Fully disconnected. | 2017-02-08 07:34:21 Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-02-08 07:34:21 STILL NO CONNECTION TO SIERRA CHART ON OTHER COMPUTER VERSION 1307 |
[2017-02-08 10:16:45] |
You need to install the DTN IQ Feed software. You can download this from this page: https://www.iqfeed.net/SierraChart/index.cfm?displayaction=startindex.cfm?displayaction=support§ion=download Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
